d 10
john2189
04-06-2008 06:24:02
is the d10 a modern version of the B ?
morton
04-06-2008 19:38:51
 Re: d 10 in reply to john2189, 04-06-2008 06:24:02
D-10 = Newer B, Had same wheel width as B
D-12 = Newer CA, Had same wheel width as CA
B and C used the CE engine
D-10 and D-12 shared the same engine (not the CE engine though)
B/D10 was 1 row, CA/D12 was 2 row.
Texas Denny
04-06-2008 07:52:05
It is hard to tell. They made the last B and CA tractors in 1957. They amde the first D-10 and D-12 tractors in 1959. The D-10 had a narrower stance (tread width and length) like the B and the D-12 had a similar stance to the CA. But the engines in the D-10 and D-12 were the same but bigger than those in the B and CA (which also had the same size engines. I think you could call the D-10 a replacement for the B and the D-12 a replacement for the CA.
Jeff Z.
04-06-2008 06:56:37
More like a souped-up CA
DiyDave
04-07-2008 09:44:10
 Re: d 10 in reply to Jeff Z., 04-06-2008 06:56:37
Actually they are more like a downsized D-14, as they both use that motor!
