Char-Lynn power steering
Gene-IA
04-20-2008 05:09:04
Just bought a WD with a Char-Lynn power steering. The owner said he has trouble "holding the o'rings" in the power steering. Is this a problem with all Char-Lynn power steering or is he using the wrong o'rings? Perhaps I should sell the WD and buy a WD45 with factory power steering? Thanks for your help.
Gene
Joe(TX)
04-21-2008 09:33:45
 Re: Char-Lynn power steering in reply to Gene-IA, 04-20-2008 05:09:04
The o rings are a symtom and not the problem. Something else is wrong such as pump pressure, improper installation, bushing/shaft worn, etc
K-Mo
04-20-2008 05:17:24
If your are talking about the o'rings on the input & output shaft, you can use what they call a "quad ring". Check with www.forceamerica.com.
K-Mo
