Re: 190 XT HYDRAULIC PROBLEM
Mickey Polk
04-22-2008 20:08:02
I understand that a seal must be leaking. However, I read a post here that talked about running a hose from the drain plugs on each side allowing the fluid to equalize back into the hyd side. I did that and it is working fine.
Big Hunter
04-23-2008 11:42:39
 Re: 190 XT HYDRAULIC PROBLEM in reply to Mickey Polk, 04-22-2008 20:08:02
that's not a fix, that's a band-aid
Big Hunter
04-23-2008 11:43:51
 Re: 190 XT HYDRAULIC PROBLEM in reply to Big Hunter, 04-23-2008 11:42:39
plus your going to be mixing 2 different weigh oils.
Mickey Polk
04-24-2008 12:32:19
 Re: 190 XT HYDRAULIC PROBLEM in reply to Big Hunter, 04-23-2008 11:43:51
the hydr and the tranny use the same fluid
Big Hunter
04-25-2008 01:49:31
 Re: 190 XT HYDRAULIC PROBLEM in reply to Mickey Polk, 04-24-2008 12:32:19
wrong
