Gleaner E motor
allisboy
04-26-2008 09:00:53
im thinking about putting a gleaner E motor in my WD45, we have been having engine problems and i want a little more horsepower, im wondering what you would have to pay to get an engine that runs with no problems.
Jerry Coulter
04-26-2008 10:20:31
 Re: Gleaner E motor in reply to allisboy, 04-26-2008 09:00:53
I have a couple of E engines, one is stuck. I know nothing about them otherwise. I keep the manifold, carb, starter and gen, you get your pick for $300 cash and carry. I am located 50 miles SE of St. Louis (62257). You understand that you would need to change the governor since the setup for the E is 1400 RPM.
Skyhighballoon(MO)
04-26-2008 12:38:26
 Re: Gleaner E motor in reply to Jerry Coulter, 04-26-2008 10:20:31
You'll need to swap over the D17 governor as the E governer is meant to run at idle or wide open and not much in between. Jerry - the E & EIII 226 engines had the same rated engine speed of 1650 as the D17 tractors. I own both a D17 and an EIII plus I checked an operator's manual I have for a straight E and they are all 1650. Mike
greg b
04-26-2008 09:19:23
look on ebay they have a couple wd engines and a combine engine for $850
