White/Oliver 1610 loader on a D-17 series IV
2-105
04-28-2008 11:40:16
Has anyone seen or put a 1610 White loader on a D-17 series IV? Does this tractor still use the high pressure system? Will it handle the loader?
Any input is appreciated. Thanks.
Skyhighballoon(MO)
04-28-2008 12:32:45
 Re: White/Oliver 1610 loader on a D-17 series IV in reply to 2-105, 04-28-2008 11:40:16
The D17 Series IV had standard pressure (e.g. approx 2000 psi) hydraulics. The pump is rated at roughly 10 gpm. Some units came with single remotes, some with double remotes so check that if you plan to run it that way and not plumb it in directly. I'm not familiar with the loader size/weight & brackets but I'd not recommend it if does not have the brackets that extend back to and bolt up to the rear axles. You could break the torque tube if it doesn't have them. Mike
