AC 7045 water temp
alliswd45
05-10-2008 12:31:42
We have a 7045 with about 6600 hours, doesn't seem to want to run at a low temp, it wants to run above 210*-250*, witch is max temp, yesterday I ran it and it stayed below 210*, any ideas, by the way, we're blowing out the radiator right now (2:40pm), looked to be pretty dirty, is that the problem.
alliswd45
05-12-2008 17:59:23
 Re: AC 7045 water temp in reply to alliswd45, 05-10-2008 12:31:42
Found the problem, a pile off dirt came out of that radiator, prabably never been cleaned, disked for 3 hours the other day, in the hills, never got above 210* running at 2500rpm
BobHnwOh
05-13-2008 03:53:15
 Re: AC 7045 water temp in reply to alliswd45, 05-12-2008 17:59:23
You better cut that back to 2300 RPM max>!!!
cadet trooper
05-11-2008 15:58:10
45 after you clean the radiator fins you may want to look at the side panel foam seals this has beem a problem with the 7000 series.
Mtoh
05-11-2008 11:10:35
I agree, I don"t think it would actually run at 250 for long so I would check the gauge for accuracy and if needed maybe change the thermostat after that.
BobHnwOh
05-10-2008 15:56:55
My 7060 gauge will show too hot sometimes,hit it with my knuckle it will drop back to normal temp.
