Pulling Carb
alliswd45
05-18-2008 12:47:25
I have a D-17 with 240 ci, flat top high compression pistons and I still need more power, does anyone know where i could get a good high performance pulling carb, i'm thinking about getting one from Denny's Carb shop, but i'm just wondering what else is out there.Thanks
mlpankey
05-19-2008 04:05:08
 Re: Pulling Carb in reply to alliswd45, 05-18-2008 12:47:25
try to find a usx21 from a 4010 john deere . it will feed you plenty . ive tried three or four carbs and go back to the 21 everytime
alliswd45
05-20-2008 15:06:48
 Re: Pulling Carb in reply to mlpankey, 05-19-2008 04:05:08
so the 4010 carb will bolt right on and hook right up, or do i have to do some alterating
mlpankey
05-21-2008 07:00:55
 Re: Pulling Carb in reply to alliswd45, 05-20-2008 15:06:48
you have to do some altering to use the usx21. you can use a tsx 977 off a ford 4000 need to use the throttle shaft from a 464 and it will bolt right up . 977 supplies my motor enough to run 3200 rpms the usx21 will let it run up to 5600 and i have a bunch more cubes with 14.1 compression. the 977 has the same venturi as a carb from a 175 gas and there alot cheaper from newholland than from agco.
