51 model WD45 tractor (gas)
Gene
12-15-1999 15:06:30
I own a WD45 gas and would like to know if the WD45 diesel engine will fit my tractor and if so who has a running engine that I could buy. My engine runs good though leaks oil a lot but I prefer the diesel. I am locaated in the south central region of the U.S.
Bryan
12-17-1999 09:24:42
 Re: 51 model WD45 tractor (gas) in reply to Gene, 12-15-1999 15:06:30
If I am reading this right and you say you have a 1951, you may have a WD instead of a 45. I would wonder if the clutches and Transmission in a straight WD would handle the diesel's power. Just a thought.
Good luck
Gene
01-05-2000 20:28:14
 Re: Re: 51 model WD45 tractor (gas) in reply to Bryan, 12-17-1999 09:24:42
to Bryan, Paul, and Bud. I made a typo on the year model of my tractor. It's a 55 and have been told that the Buda 6 cylinder will work and the transmission will take the torque. Thanks for your input.
Gene
01-05-2000 20:27:45
Gene
01-05-2000 20:27:22
Paul Anderson
12-16-1999 17:50:26
Gene, also the left frame rail is bent down in the front to make room for the fuel pump, Paul Anderson
Bud
12-15-1999 20:59:23
Gene the six cylinder Buda diesel will fit although you will have to find a longer hood also and convert the lights to 12 volt and generator. I bought my third 45 diesel in about 40 years in OK last fall it is complete and runs excellent. I do have books ect as farmed with them for years I am located in SE Iowa
