A/C Mod. C with a short
Mike
08-30-1998 08:54:12
I need a wire diagram of a mod. C . Every time i put the cover for the switches on i get a spark like something is shorted .Is this normal ?
robert mull
08-30-1998 16:12:46
 Re: A/C Mod. C with a short in reply to Mike, 08-30-1998 08:54:12
: I need a wire diagram of a mod. C . Every time i put the cover for the switches on i get a spark like something is shorted .Is this normal ?
The generator will not charge unless the cover on the switch box is screwed on tight ,so you would get a spark if the engine is running. Got a fax # I will send you a copy of the diagram.
