190XT hydrolic oil problem
Jack Almquist
02-12-2000 17:56:43
This approximately 64-65 model. The problem I am having is the left reservoir is running out of oil and the right reservoir is overfilling. I can only operate the tractor for a short time before having to drain out of one side into the other. Has anyone had a similar problem or know how this can be resolved.
Dave
01-01-2004 15:24:32
 Re: 190XT hydrolic oil problem in reply to Jack Almquist, 02-12-2000 17:56:43
My Brother bought a 190XT III and it was that way also in about 10 min all the oil was out of hydrolic and into trans. We looked it over and discovered that on the hydrolic dipstick was suppose to be vented and checked balled. We cleaned out vent and took out the check ball. Guess what. PROBLEM SOLVED. He Has been using it for 2 years now and only time hydrolic oil is low now is because loosing it at the cly couplers.
Hope this helps Yours to. If so You can send Me a check for whatever You think this was worth. Dave
S. Kashefi
09-23-2001 23:21:33
Dear sir,
Please be informed that we are looking for 4 PCs of hydrolic jack each tons1500 with a main power as feeder for the 4 PCs jacks the same time with 300m hoses.
Please find more information in hereafter:
High of each jack ( H ) 75cm
Diameter of Jack ( OD ) 80cm
Course of jack ( C ) 15cm
Capacity of jack 1500 tons
Incase you could supply jack with capacity 1000 tons with the specification as above
quantity should 6 jacks.
Please do not Hesitate to contact with ECCO:
E-mail: ecco@kanoon.net
Tel: +98 21 873 6132
Fax: +98 21 874 0051
we look forward to hearing from you soon.
Best regards
S. Kashefi
farhad
05-28-2001 22:50:51
Jim Bunch
08-06-2000 10:47:37
I am having the same problem with my 190 xt also.
I have been using a suction pump and pulling the fluid from the transmission side to the hydraulic side.
This does not take too long and is alot cheaper than having it broken into and repaired.
Have also found that if i park on a sloop for afew minutes this will help also.
My mechanic states that if we break it into that several ac owners have just drilled a equalizing hole between both units other than try and replace the seal since sometimes when its put back together the seal will tear anyway.
Gordon Chance
02-13-2000 12:28:30
Jack:
The reason that your oil is transferring is because the rubber seal on the input shaft of the transmission has separated from the metal casing and is allowing the excess oil from the power director clutch to transfer into the transmission. The tractor will have to be split between the transmissiona and the torque tube to replace this seal. If you want to attempt this repair yourself, I would reccomend obtaining a service manual before proceeding. There is an alternative solution to your problem but you will have to E-mail me for this as it is too long to post here. Have a good day.
Gordon
Jim Brown
10-25-2000 07:01:07
 Re: Re: 190XT hydrolic oil problem in reply to Gordon Chance, 02-13-2000 12:28:30
Gordan, I am having the same problem. Could you please send me your alternative? Thanks in advance, Jim in Missouri.
Jim Brown
10-25-2000 07:09:51
 Re: Re: Re: 190XT hydrolic oil problem in reply to Jim Brown, 10-25-2000 07:01:07
Gordan; I am having the same problem. Would you please E-Mail your alternative? Thanks in advance. Jim in Missouri
Red Man
02-13-2000 12:13:46
We had a 190 years ago that had the same problem, there is a seal between the transmission and rear-end that has to be replaced.
