A-c wc
Terry
03-06-2000 09:22:17
Does anyone know if there is a wide-front end available for the A-C WC. Would a wide-front from a WD or WD-45 work?
Patrick
03-06-2000 17:02:18
 Re: a-c wc in reply to Terry, 03-06-2000 09:22:17
According to a Norm Swinford book a wide front end was available.
Brian G.
03-07-2000 05:05:52
 Re: Re: a-c wc in reply to Patrick, 03-06-2000 17:02:18
I've never seen a WC with a wide front but as Patrick says, they were available. I have a WC manual which shows it also. It was a non-adjustable axle with an arch. It looks a little like a "B" non-adjustable wide front; only much heavier. After someone else asked the same question about the WD wide front on a WC a few months ago, I took the measurements off my brother's WC narrow front and my WD-45 wide front and found that all the measurements are the same (including the location of the steering shaft bearing next to the u-joint). It looks like a "bolt-in" swap. As I recall, someone on this site (or the "Unofficial Allis" site) once said he had heard it was done by a few farmers.
