39 WC Manifold availability
Russ
03-26-2000 17:58:58
I was wondering if any body Knows where I can find a in-ex manifold for a 39 WC allis. And also how many different versions of this manifold there are?
Aaron
03-26-2000 18:25:04
 Re: 39 WC Manifold availability in reply to Russ, 03-26-2000 17:58:58
That is the same manifold that they used on all WC's. here are 2.5 versions of manifolds for them. There is the one with the exhaust through the hood, the side discharge one pointed up, and the side discharge one going down. Depending on what hood you have, I think they are fairly easy to find in the right salvage yard.
Aaron
Russ
03-26-2000 18:31:16
 Re: Re: 39 WC Manifold availability in reply to Aaron, 03-26-2000 18:25:04
I was told that the manifolds will fit from WC on up to D17 but I have a manifold from a D17 and it is different. I'm sure it will bolt up. And i think the carb will work also but it would not be original. Also every manifold i have found is in the same rusted out condition as mine.
