Re: 12volt conversion
JOHN IN NY
04-07-2000 04:49:34
THE BEST PLACE TO GET THEM IS RADIO SHACK. 2 IN A PACKAGE FOR 49 CENTS.
Hilltopper
04-07-2000 13:40:42
 Re: Re: 12volt conversion in reply to JOHN IN NY, 04-07-2000 04:49:34
On my 12 volt conversion the hot side of the coil goes through the ignition switch. Switch off, no power to coil. I thought all the conversions were wired this way.
Richard (KS)
04-07-2000 13:46:55
 Re: Re: Re: 12volt conversion in reply to Hilltopper, 04-07-2000 13:40:42
The problem is that the field circuit of the alternator feeds back through the system and keeps the coil energized. Where I work we commonly run the field excitation through an oil pressure switch, or you could use a double-pole single-throw switch, to switch the field current independently of the ignition and other "B+" circuits.
