"C" Front End
RM from IL
11-02-1998 10:49:16
Anyone out there have a good (safe) way to jack
up the front end of a "C"? I need to rebuild it because it 'snakes' so much when I'm mowing that
I feel (and look!) like a little kid pretending
to drive Daddy's car! Any suggestions? Thanks.
Hunter
07-02-2000 20:19:48
 Re: in reply to RM from IL, 11-02-1998 10:49:16
I'm not shure ifthis is what you want I'm only 14 and restoring a model C and thats what I did.
On the Transmission housing or case i'm not sure what it's called. There should be two holes with threads in them on each side, get some angle iron and bolt on two them and make a stand. For the back, you can take the fron off there should be 4 bolts on the bottom by the radiator you can go ahead and take it off but your going to have to disconect the hoses to the radiator. Then you have the block by it's self.
