AC 200 Fuel system
Bill
06-03-2000 14:27:12
My 200 will start momentarily then stall.
There is some air in the top of the 2nd
filter (nearest the pump). I have tried
to use the small pump to get it out but
the pump seems to do nothing.
Is there any way to do this without using the pump? Is there another problem I might
be overlooking?
Thanks,
Bill
Bill in Mich
06-05-2000 20:55:45
 Re: AC 200 Fuel system in reply to Bill, 06-03-2000 14:27:12
Im not sure if your hand pump is the same as my 190, but if it is, pop the snap clip off the hand pump and pull out the plunger to see if the rubber plunger cup has come off the plunger handle. This happened to my pump. AC has new plungers for about $25, Bill
Gordon Chance
06-04-2000 18:17:51
Bill:
Your problem is a plugged return line fitting on top of the pump that is getting plugged from a deteriorating governor ring inside of the pump. There is a glass ball and a spring in the return line fitting that is catching the debris from the governor ring. A temporary fix for this is to break the glass ball and remove it from the fitting. This will allow the debris to pass through and go back to the tank. This will get you running but it is advisable to remove the pump and have it repaired at a pump station because if the governor ring deteriorates enough that it would let go, then you would have a run away engine and cause lots of damage. I hope that this helps.
Gordon
