185 pto keeps running
lb
06-16-2000 21:16:25
I have a 185 that has a pto that will only stop turning when I push in on the foot clutch.Also, where do you adjust the brakes? They are almost non-existant.Thanks for any help.
ben
06-19-2000 18:30:02
 Re: 185 pto keeps running in reply to lb, 06-16-2000 21:16:25
ib. if you have a hy. pto the brakes pad are probley worn out or one of the clutch disk is broken in the clutch pack. on the wheel brakes to adjust the brakes turn the turnbuckle on the left brake under the battery box the right brake is adjusted by turning the rod into the brake drum most of the time thies are frozen so be carefull not to brake the rod with a little work back and forth they will come lose if not you will have to replace the brake linings and bands. ben.
