Overhaul an G-model Allis Chalmers
Al Paschall
06-27-2000 13:41:49
I've got a G-model and it needs an overhaul. Does anyone have any ideas about the difficulty of such a project? Approximate costs? Things unique to the G that might cause a problem?
Any comments or help would be appreciated.
Al Paschall
Humboldt, TN
Warren Newton
06-27-2000 19:40:11
 Re: Overhaul an G-model Allis Chalmers in reply to Al Paschall, 06-27-2000 13:41:49
I worked on one a couple of years ago. you can get parts at most auto parts stores. It is a N-62 contenial motor. My motor was stuck. It was the valve guides that were rusted up, not the pistons. Massy Harris pony and some cub farmalls have the same motor
Robert Mull
06-27-2000 14:07:22
The "G" does not have sleeves so if it needs boring ($40-50 ) you will have the additional cost of larger pistons. Rings are between $50-55. Rod bearings are Between $50-55 also. I paid $12.00 each for wrist pin bushings (too much) and had them fitted to the rods for $6.00 each.A gasket set will cost you $70.00 from NAPA ,but I found one on E-bay for $30.00
