1948 Model C muffler type
Burl
06-28-2000 02:23:19
Any info on how to tell which muffler is the correct one for this tractor? My manual isn't real clear. The engine number is CR42430. Thanks.
Ron
06-29-2000 00:26:32
 Re: 1948 Model C muffler type in reply to Burl, 06-28-2000 02:23:19
Try TSC blue book ac-1 ac-2 and ac-3
Burl
06-29-2000 03:39:59
 Re: Re: 1948 Model C muffler type in reply to Ron, 06-29-2000 00:26:32
Thanks Ron. That looks like a good site. I'm new to AC's, been doing JD's. Half the battle in this hobby is getting your reference listing together. I really appreciate your help.
Rick in NC
06-28-2000 09:27:42
Burl,
I use the one with the Model # AC-1, but I can't remember the name of the muffler company. It is the one that you see in all of the farm supply stores. I like it better than the AC-3 that is recommended in the catalog because it has a longer pipe that runs from the exhaust manifold to the muffler. The hood on my 1950 Model B does not have a hole in it large enough to accomodate the AC-3 that has a shorter pipe and requires that a part of the muffler body fit through the hood.
The AC-1 has the single bolt mounting instead of the two holes and bracket required on later models.
Rick in NC
07-05-2000 10:21:05
 Re: Re: Re: 1948 Model C muffler type in reply to Burl, 06-28-2000 15:12:46
The name of the muffler company is Stanley. If you go to most of the farm supply houses, the muffler catalog will be hanging close to the mufflers. I am sure Stanley is not the only manufacturer of replacement tractor mufflers, but is the predominant one here in Eastern NC. In their catalog, they will be numbered AC-1, AC-3, etc. They even have the little underhood muffler that was on a lot of the Model B's.
