Ugly tractors
acd17toy Jim
07-10-2000 19:25:19
to me the case SC,the DC, are about the ugliest tractors ever made. lets hear other peoples ideas.
ron
07-11-2000 18:25:04
 Re: ugly tractors in reply to acd17toy Jim, 07-10-2000 19:25:19
Anything green!
Tyler(WA)
07-11-2000 09:49:45
Never seen an ugly tractor. Some look different than others but all share a part in the history and support of farmers. There isn't anything ugly about that.
D13
07-12-2000 03:55:22
 Re: Re: ugly tractors in reply to Tyler(WA), 07-11-2000 09:49:45
Tyler, you should see my Oliver Super55. It's originally gren, yellow repaint, without proper prep or rust removal. Now it's yellow with rust and green highlights. It has a Mercer (??!!) loader, rust with a little yellow, that has about 10 lbs of weld on it. The replacement steering column is green and waves around as a GM steering box that replaces the original has broken its fabricated mountings. The one tie rod is welded to length and unpainted. Both spindles have had the arms welded to them, then broken, then large triangles welded to the stubs. A drag link saws on the lower radiator hose so it drips coolant, that is when the leaking water pump is done. As the geometry of the steering is off it will not turn right more than 5 degrees but it will happily go left. It leaks engine oil, hydralic fluid, and trans oil. THe tires are weather chedked and I am waiting for the chloride leak. When running every thing on the tractor rattles. It truely is ugly, and I love it!
Of course my Allis B is beautiful.... ALthough I think the oliver 770 Dad had was still my favorite.
Tyler(WA)
07-12-2000 06:33:19
 Re: Re: Re: ugly tractors in reply to D13, 07-12-2000 03:55:22
third party image
Mr. Douglas! Mr. DOUGLAS!
Can I get a picture of you on your Hoyt Calgwell?
(Thanks for the description.)
