7010 trans trouble
phillip
10-18-2000 07:00:30
transmission slips 3rd&reverse transmission is a power shift type any body have an idea
skipwelte
10-19-2000 08:10:52
 Re: 7010 trans trouble in reply to phillip, 10-18-2000 07:00:30
phil, sound like one of the clutch packs inside the trans is slipping. First of all Id check the trans pressure and if its low get it raised back up to spec, then try it. If its already up to spec your probably looking at a trans overhaul. Right off hand I cant remember if 3rd and rev share a clutch, if they do, then its only one clutch slipping. If they dont could be more than one slipping.
