1942 AC C Gear box oil
Fred
10-22-2000 16:52:56
Read previous message on gear box oil change. I changed my 20w oil , but I only removed the center plug to drain it out, there are actually 3 drain plugs under mine. Why three? and should I remove them all next time?
David (Ala)
10-24-2000 09:22:34
 Re: 1942 AC C Gear box oil in reply to Fred, 10-22-2000 16:52:56
There are three plugs. One for each compartment.Hyd., diff., and trans. They have a dam between them to prevent all fluid running to one end on inclines. You have to drain all three to completely drain combined units. Hope this helps. David (Alabama)
