AC 180 wont stay stay where I left it.
matt
10-23-2000 08:43:02
Have a 180 Diesel that when I park will not stop rolling if left on any incline. The manual says the hand clutch should be in neutral but it does not matter where it is, high, neutral, low. The tractor will still roll in gear. Am I missing something or is something not as it should be. This is the first AC I have ever had but any other tractor I park in gear stays where I put it. Tractor runs and works fine with no other problems. Any ideas? Thank you in advance.
Darrell (MN)
10-23-2000 18:10:45
 Re: AC 180 wont stay stay where I left it. in reply to matt, 10-23-2000 08:43:02
Matt, the reason that your tractor is rolling away is because the power director (high/low) clutch is run from hydraulic power...turn off tractor, turn off hydrualic power. You will also find out that you can't pull start your 180 for the same reason. The safest way to keep it where you left it, is to set the parking brakes. Darrell (MN)
Jeff
10-23-2000 16:32:11
If it has the same set up as my 200 you have to lock the parking brake to make it sit still. IH 806 and 706 ect are the same way .
