A-C D10
MARTY R. BYLER
10-31-2000 19:48:14
I,am wanting to restore my D10. It needs a few parts. fenders,R-H panel under gas tank, manifold, complete air breather asseambly,wiring harness, Cyl-Head, drag link, steering wheel. the housing the Distributor bolts to,& etc. Do,es anyone know where I could find these parts. Thank You. Marty.
muss
03-19-2001 18:40:46
 Re: A-C D10 in reply to MARTY R. BYLER, 10-31-2000 19:48:14
if i can't figure a way to get mine running right i will soon be having alot of spare parts!!
hope my tractor is listening in, it might start running properly.
Paul
11-05-2000 18:13:19
I can help with a few items : I have the panels for under the gas tank, sanded & primed $35 and the aluminum housing to mount the distrbuter $50
MARTY R BYLER
11-06-2000 05:59:40
 Re: Re: A-C D10 in reply to Paul, 11-05-2000 18:13:19
I want those parts.Let me know where or how I can send you the money and how much the shipping is.You can call me in the evening any time after 7.oo. I,am also looking for a R-H axle with wleel spindle and lug nuts. I messed mine up trying to get the twisted off lug nuts out of the spindle THANKS MARTY.
Paul
11-06-2000 20:08:01
 Re: Re: Re: A-C D10 in reply to MARTY R BYLER, 11-06-2000 05:59:40
Marty: If you Email me directly I can give you all the details. my address is: orangewizard@webtv.net If the axle spindle is the same for a CA & D10 (and I'm almost positive they are) I have a couple of those too $75 each
MARTY R BYLER
11-06-2000 06:11:16
Phone Number 336-375-6654
GeneD14
11-01-2000 12:59:44
The steering wheel is the same model as used on the Gleaner E combine. They can be found at boneyards and are usually in good condition from being inside a cab. The manifold is only availible through Agco $300!! A D14 manifold can be bought on the aftermarket for $120. it will fit your engine perfectly but you will have to modify your air cleaner and hood to get them to fit.
