A.C. D-19
PAT VANDY(SHAKE
11-05-2000 15:18:03
A NEIGHBOR OF MINE HAS A D-19 FOR SALE FOR 2500.OO . THE TRACTOR RUNS VERY GOOD,IT IS DRY AND HAS NO APPARENT LEAKS,THE TIRES ARE AVERAGE, IT HAS THE SNAP COUPLER SYS. HOOD,GRILL AND BOTH FENDERS NEED REPLACING. A 3-BOTTOM A.C. PLOW ALSO GOES WITH IT. IS IT WORTH IT ? IF NOT WHAT IS IT WORTH? ARE PARTS AVAILABLE? HOW GOOD ARE THESE TRACTORS? I WELCOME YOUR COMMENTS.
Duane
11-07-2000 05:25:20
 Re: A.C. D-19 in reply to PAT VANDY(SHAKERHOOD), 11-05-2000 15:18:03
A neighbor of mine has one for sale too.
He's asking $3500, it has a miss and the hyd. is not working. Sheet metal is good. Needless to say, I think he's asking tooooo much.
tim[in]
11-08-2000 13:49:28
 Re: Re: A.C. D-19 in reply to Duane, 11-07-2000 05:25:20
my dealer told me that d 19s had a lot of hydraulic probs too. i dont know how true this is.
ROBERT
11-08-2000 19:29:09
 Re: Re: Re: A.C. D-19 in reply to tim[in], 11-08-2000 13:49:28
the hyd was not fast ,uther than that thay work
fine for years. ROBERT
tim[in]
11-09-2000 03:23:17
 Re: Re: Re: Re: A.C. D-19 in reply to ROBERT, 11-08-2000 19:29:09
thanks for clearing that up. i have wondered . there are some things that require more power than my 17 has so i have wondered about a d-19. thought about one years ago but didnt because of the hydraulic question.
LB
11-06-2000 16:16:59
Hi, I think if you have to replace the sheetmetal then you should try to get it for under $2000. Some like gas over diesel, but for economy the diesel is much better. The diesels did have more problems with the engine, but if you take care, it should be ok. Also check to see if it pops out of 3rd gear. It costs several thousand dollars to have a shop fix 3rd gear.
LazyHorse
11-05-2000 17:02:22
In my area D17's go for around $3000 on average. Don't recall the last time Isaw a 19 for sale. I would say $2500 is reasonable. I would guess you can get the sheetmetal if what you have can't be fixed. You can also get a 3 point conversion for the snap coupler which will make it a lot easier to use modern implements.
