52 CA HYDRAULIC LEAK
NICK W. (IN)
11-14-2000 17:10:21
I BELIEVE I HAVE PINPOINTED MY LEAK TO THE DIFFERENTIAL HOUSING, COULD THIS BE BAD OIL SEALS? AND IF SO WHAT KIND OF TASK IS IT TO CHANGE THEM?
I WOULD ALSO LIKE TO KNOW IF WOULD BE A GOOD IDEA TO FLUSH OUT TRANS, DIFF, WITH SOLVENT, OR WILL THIS CAUSE DAMAGE. THANKS NICK
Dick L
11-15-2000 18:25:58
 Re: 52 CA HYDRAULIC LEAK in reply to NICK W. (IN), 11-14-2000 17:10:21
third party image
Nick, here is a picture that you can see where the seal is through the axle hole.
The mouse nest was not yet cleaned off when I took the picture. There is four bolts that hold the bearing cap onto the housing. The seal is in the bearing cap. As you can see you will have to take the final drive castings off to get to them.
Sandy Lake Implement
11-15-2000 18:23:51
We flush housings with diesel fuel. Sometimes
we find it necessary to mix oil & diesel 50/50
and drive the tractor a few minutes, then drain.
Dick L
11-15-2000 20:21:37
 Re: Re: 52 CA HYDRAULIC LEAK in reply to Sandy Lake Implement, 11-15-2000 18:23:51
third party image
I power washed this one
