AC C or CA?
'Bandit'
12-10-2000 19:04:59
I have recently bought a mid 40's Allis. It was used to take care of the grounds at a church, it's been there since the invention of dirt and noone knows exactly what year it is, or whether it is a C or CA. Is there anything i can look at to see? It has a tricycle setup. Until now we've only used Farmalls on our farm. So i don't know much about anything else. If anyone could gimme an address or web site that says where i might aquire new sheet metal parts too would be greatly appreciated. Thanks
john
12-11-2000 09:18:15
 Re: AC C or CA? in reply to 'Bandit', 12-10-2000 19:04:59
The C originally came with a bench type seat, the CA came with a typical tractor type pan seat.
'Bandit'
12-11-2000 12:25:05
 Re: Re: AC C or CA? in reply to john, 12-11-2000 09:18:15
I have a C, thanks...
Dan
12-11-2000 04:46:44
Mid-forties Allis could not be CA. CA built first in 1950.
Tadams
12-11-2000 04:28:58
If you look at the flat area by the grear shift you will find serial # if it is a C it will start with a C, if it is a CA it will start with a CA, then you go to the serial number section of this page and find year.
Tom
T Seifert
12-10-2000 20:17:46
A CA has a hand clutch a C does not.
A CA has a sheet metal platform under your feet a C does not.
A CA has a 1 3/8" pto shaft a C has 1 1/8"
Those are quick ones.
Ted
john garringer
12-15-2000 18:07:28
 Re: Re: AC C or CA? in reply to T Seifert, 12-10-2000 20:17:46
CA does not have hand clutch as CA was not built until 1950, also CA does not have sheetmetal under feet, CA has 4 speed trans and CA also have 1 person pan type seat, C has bench.
'Bandit'
12-10-2000 20:19:59
OK thats great, thanks,
it looks like I have a C
