A c model B
Emery Klein
12-14-2000 16:51:36
Thanks everyone for the help I now know it is a B model. The ser.# B102851 any body know what year this is. My problem with the starter is that it will spin but not engauge against flywheel.
Emery
12-22-2000 08:58:14
 Re: a c model B in reply to Emery Klein, 12-14-2000 16:51:36
Thanks for all your replys.Sorry I didn't answer sooner I was out of town.I am going to mess with it this weekend will post a reply on results Mon. or Tues. thanks again.
Emery
12-22-2000 08:55:55
Greg Ballantyne
12-17-2000 19:35:02
I have a '49 B, starter spins but does not engage. My starter does not have a broken spring, nor is it a dirty starter. There is a large nut behind the drive gear, hollowed out on the side toward the starter body. The spring extends into the "hollowed" part. When the gear retracts, it comes to rest on the shoulder of the shaft, still spinning when contact is made. Over time the nut and the shaft shoulder wear, until thy fit more tightly together. Eventually they wedge together quite tightly. My starter got so it would stick sometimes, then most of the time, but rapping it with a wrench or a hammer would free it. Then it progressed to where the starter had to be removed to free them up, and you could get one start out of it before it stuck again. The last time I had it off it was very difficult to free it. I know I need another starter, but I just use the crank now.
Lowell
12-15-2000 22:03:24
If you look under research and Info on the left of this screen you will see serial No's. Follow the curser. I know I had to ask too, sort of embarassing!!!
Sandy Lake Implement
12-14-2000 20:33:07
I agree, sounds like a broken drive spring.
We can supply a replacement or a new drive asy
that no longer uses the spring. E mail or ph 724-376-2489 8-5 eastern if interested.
T Adams
12-14-2000 19:21:55
Emery I guess you have a broken starter spring cause by dirty engage drive gear, easy to happen in cold weather.
Ron Rasnic
12-14-2000 18:46:16
Emery I forgot to say that it sounds like you have a real durty or bad starter drive. Ron
Ron Rasnic
12-14-2000 18:39:57
Emery it is a 1950 I have 102850
Ron
Emery
12-22-2000 08:47:43
 Re: Re: a c model B in reply to Ron Rasnic, 12-14-2000 18:39:57
Ron, I live in North Carolina.I'm interested in knowing if you are close,I got the tractor from the mountians of the state.Also i'm sorry I didn't reply sooner.Out of town.I will be working on the starter problem this weekend.Will post a reply Mon. or TUES. Thanks Emery
Brian G.
12-15-2000 06:59:19
Do you guys live near each other? That's a real coincidence. I once looked at a WD that had a serial number within 6 digits of mine. It was located on a farm about 25 miles from where I bought mine so I assume they were both bought at about the same time from the same dealer.
