WD45 Hydraulics
ACMAN
12-17-2000 12:25:52
Can a 2 way valve be plugged in to the remote outlet and run back to resivour?
Randy
12-17-2000 17:19:00
 Re: WD45 Hydraulics in reply to ACMAN, 12-17-2000 12:25:52
Yes it will work,put a shut off on your tractor cylinders and run the hyd. directly to the 2way valve with a relief to be preset about 2,000psi since the tractor hyd. system is high presure and and probaby your impliment is low presure system. You can dump the oil from the valve back in the refill on the tractor. Hope this helps!
ACMAN
12-17-2000 18:36:54
 Re: Re: WD45 Hydraulics in reply to Randy, 12-17-2000 17:19:00
Thanks Randy. The tractor will not hold a blade at a even height either, could a remote type valve be used here? Or any other thoughts?
Randy
12-17-2000 17:18:51
