AC 48 Model B Help I am Stuck
Ironhorse
12-22-2000 20:48:49
Need to Know how the control Arm for the Radaitor shutters Comes apart Everything is stuck tight I have soak it all with gibbs and need to know what to break apart First or were it comes apart. So I can remove the grill.
Thanks Happy Holidays
Dick L
12-23-2000 04:54:11
 Re: AC 48 Model B Help I am Stuck in reply to Ironhorse, 12-22-2000 20:48:49
third party image
This is the best drawing I could find.
You will have to take the grill or radiator shell off. You will then see a cotter key on the threaded rod that hooks into the arms fasten to the fins. You will also see the inner end of the crank handle goes through an angle retainer with another retainer device holding the crank into this angle. Because of rust this retainer may have to be heated to remove or even ground away.
After you have this unit out you may be able to clamp the rod part in a vice and by heating the threaded crank handle red hot work it back and forth and get it to turn out depending on how bad it is rusted. I have had more that I have had to drill out and make new rods for than I have been able to save.
