Dual wheeled C?
'Bandit'
01-01-2001 20:09:06
Can i put dualies on a AC-C safely, or would this not be recomended? Also what is the equivalent sized farmall tractor to a C? Could anyone tell me?
Thanks
Darrell (MN)
01-03-2001 17:42:47
 Re: dual wheeled C? in reply to 'Bandit', 01-01-2001 20:09:06
I woul think you could turn another set of centers around and put them on the outside. You would have to find longer bolts to bolt them together, which would probably be te weakest link, but you might b able to ad some kind of blt and spacer to the wheel weight holes for added strength. Let me know how it works out. I was thinking of maybe doing the same thing. Good Luck, Darrell(MN)
'Bandit'
01-03-2001 18:51:34
 Re: Re: dual wheeled C? in reply to Darrell (MN), 01-03-2001 17:42:47
alright, i'll give it a go and see how it works,
there are those graded bolts that might work under heavy stress
Phil Auten (TX)
01-02-2001 19:04:56
Bandit,
There used to be a pic of either a B or C in the photo archives with duals. It can be done, but the picture doesen't show details.
Phil
'Bandit'
01-02-2001 19:25:14
 Re: Re: dual wheeled C? in reply to Phil Auten (TX), 01-02-2001 19:04:56
ok i'll check it out, thanks
Duane
01-02-2001 17:17:22
I would say it is close to the Farmall C. I believe the Farmall C had about 15hp drawbar and 20hp PTO.
'Bandit'
01-02-2001 17:59:30
 Re: Re: dual wheeled C? in reply to Duane, 01-02-2001 17:17:22
Thanks alot, really appreciate the help.
'Bandit' C'mon little help....
01-02-2001 15:28:12
