12-V generator
Larry
01-03-2001 07:13:46
There was a 12-V generator on my 52 CA when purchased,can someone tell me if it requires a positive ground like 6 volt?
tseifert
01-03-2001 09:55:20
 Re: 12-V generator in reply to Larry, 01-03-2001 07:13:46
A negative ground will work if the generator and regulator are negative ground. The starter doesn't care about polarity, the lights don't care, only the amp meter cares and reversing the wires on the terminals will fix that.
Ted
Brian G.
01-03-2001 15:13:07
 Re: Re: 12-V generator in reply to tseifert, 01-03-2001 09:55:20
The coil might "care" a little too.
