'C' block cracks between sleeves
mark dingbaum
01-03-2001 08:28:20
Hello,
I've got my '42 C apart and the 'bridges' at the top of the block between the sleeves are cracked.
Is this a problem? I'll be instaling new sleeves and pistons and am considering decking the block, should these bridges be welded first?
thanks for the help,
mark
mark dingbaum
01-05-2001 08:17:07
 Re: 'C' block cracks between sleeves in reply to mark dingbaum, 01-03-2001 08:28:20
Bad news...other cracks in block also...one 8" long.
mark
J.L.
01-19-2001 00:35:16
 Re: Re: 'C' block cracks between sleeves in reply to mark dingbaum, 01-05-2001 08:17:07
Mark; You did'nt say where other cracks are. Are they all internal or are they in the outer shell of the block? If they are, the block probablly froze one winter. This can also be fixed, but it ain't going to be easy. I would have the block boiled out and then closely inspected to determine
if it is repairable or if it will have to be replaced. Good luck.
JOHN OLINGER
01-07-2001 05:41:21
MY WC HAS THE SAME CRACKS AND IT HAS BEEN FINE.
T Seifert Austinburg OH
01-03-2001 09:47:50
Not a problem. Most B's, C's have them, the head gasket will seal the cyclendars.
Good luck
Ted
