3 point for B
bunky
01-11-2001 04:12:19
i have a allis chalmers B and want to put a 3 point hitch on it i have looked at C&D hitches and workmans is there anymore? also does anyone have one of these hitches and would give me some input on it
Ron
01-12-2001 21:02:40
 Re: 3 point for B in reply to bunky, 01-11-2001 04:12:19
third party image
Bunky if you are handy you can do it yourself I did this one for my wifes B in two hrs.
ed
01-14-2001 21:16:50
 Re: Re: 3 point for B in reply to Ron, 01-12-2001 21:02:40
Ron what parts did you use for your 3 point? Were thry allis or a mix of other mfg? I've seen a simple one like yours before but couldn't find the long links to the bolt holes. Are they cut and welded back or what? Also did you use the one hydro cylinder or two ? I don't think that one would be enough to lift much up, although mine can lift up a mounted plow. Let me know thanks Ed
Bus Driver
01-14-2001 18:39:42
Very impressive. I have been unable to get the second picture. Am I doing somethig wrong when I try to open it?
ssteve
01-13-2001 11:46:10
Ron, are the upper arms and cylinder from an original 2 point hitch, and you installed the lower arms to the gear box holes where the drawbar bolts on??? A little extra info would be appreciated, thanks.
Ron
01-13-2001 19:32:20
 Re: Re: Re: 3 point for B in reply to ssteve, 01-13-2001 11:46:10
third party image
Ssteve try this
Dave in Mo
01-11-2001 09:05:22
Worksaver sells them, assuming you have the hydraulic pump. I priced one last week for our "B" and the local distibutor wanted $515. Check the website 'www.worksaver.com'. They have the parts lists/diagrams too.
Dan
01-12-2001 19:22:27
 Re: Re: 3 point for B in reply to Dave in Mo, 01-11-2001 09:05:22
I bought my 3 point conversion for my B from Walts
in Mo. It installed with a minimal amount of horseing around.I think I had to move a hole a little.It was around $350 and was complete with a cylinder.So far I have used it quite a bit in 6 months and am pleased.good luck
