ALLIS WC-D17
AL
01-11-2001 14:53:35
IF I PUT THE CRANKSHALF OUT OF D17 IN A WC WILL I NEED THE CAMSHALF ALSO.
LB
01-12-2001 17:01:04
 Re: ALLIS WC-D17 in reply to AL, 01-11-2001 14:53:35
You could put a WD45 crank in the WC I beleave. That would give you the same stroke as the D17.
lonn
01-11-2001 21:02:58
Crankshafts won't swap unless you change blocks. D17 block will bolt in WC with some minor changes.
