Drawbar on C
'Bandit'
01-14-2001 18:31:15
how do you remove the drawbar on a AC-C?
I've taken the bolts out. Do you then pry the pin out?.... any help thanks.
J.L.
01-18-2001 23:25:35
 Re: drawbar on C in reply to 'Bandit', 01-14-2001 18:31:15
Bandit; The pins on the draw bar are notorious for siezeing in the holes. Before you pry on or heat them,[BAD IDEA],soak them well with liquid wrench, or like compound, and allow to penetrate over night. The pins should then wiggle out by hand.BE SURE TO SUPPORT THE DRAW BAR, they are heavier than they look. I had the first one I removed, drop on my foot, not something I want to repeat.
'Bandit'
01-22-2001 18:27:51
 Re: Re: drawbar on C in reply to J.L., 01-18-2001 23:25:35
thanks, i soaked them, and they tapped out.
ed
01-14-2001 21:22:29
After the bolts are out, the remaining retainer is just a smooth pin. It should wiggle free. The Allis b and c are the same, and if not stuck or rusted (they will get rusted up and hang tight) should remove easly out. Ed
