AC-C hydraulics
'Bandit'
01-14-2001 18:33:19
How do the hydraulics work. For instance how do the levers work? Turning them on? could someone give me a step by step for using them. Thanks alot....
Dick L
01-15-2001 04:45:13
 Re: AC-C hydraulics in reply to 'Bandit', 01-14-2001 18:33:19
IF every thing is hooked up correctly. engage the power takeoff, let out the clutch pedal, pull up on the lever connected to the pump and oil pumps through the hose to the cylinder. Let the lever down and the weight on what ever the cylinder is lifting will force the oil back through the pump.
When you push the clutch pedal down the pump will stop.
