AC- C hydraulics
'Bandit'
01-22-2001 18:32:18
I've cleaned the pump, and everything works. So what can i use this hyraulic unit for? can i hook to light equiptment, that have hydraulic lines? ie. plows or mowers? it has 2 original cylinders, that attach to the frame under the seat, what to they do? what can i use them for, i don't have and equiptment that they'd go with? any suggestions plz, thanks...
Joel, CT
01-22-2001 19:43:15
 Re: AC- C hydraulics in reply to 'Bandit', 01-22-2001 18:32:18
The 2 "pistons" are actually hydraulic rams. They will extend by pulling the lever on the pump, but rely on the implement weight to push them back. As I have the same tractor, implements are hard to come by for the drawbar type. I'm most likely going to convert to a 3-pt hitch so I can utilize virtually all 3-pt implements for this size tractor. Plows, brush hogs, mowers, etc. can all be used.
