Re: Re: Re: Converting a Model G to 12 volt
steve
02-04-2001 07:37:17
guys, most people know the tractor is small and can be started with 6 volts. If it is simply a wiring problem then, yea, that should be fixed. I am assuming the electrical has been checked and checked again and the problem is the generator or regulator. At this point it is more economics. Last time I checked it cost $100. to have the generator rewound and brushed. You still have a 6 volt positive ground system that is different than everything else on the farm. (at lease everything I own). If you want original thats great, but if you are going for low cost, long life and common with your other equipment, the delco alternator is a good cheep fix. I do this when its time to get a new battery also. That helps justify the cost. My tractors all use the same battery type.
John
02-04-2001 21:14:29
 Re: Re: Re: Re: Converting a Model G to 12 volt in reply to steve, 02-04-2001 07:37:17
$100 spread over 20 years is $5.00 a year!
You may lose up to 50% or more of the value of the tractor because automotive collectors are going to start wanting these small tractors for their collection but only if they are not modified.
Last a tractor which can be started using a handcrank does not need to be jump started from another battery. We want you to give reasons not your f*****g excuses.
