3 pt hyd cylinder tool
Gary Fry
02-20-2001 18:04:17
On my D-17 s4, the hyd cylinders are leaking badly so I am borrowing a tool to unscrew the top off the cylinder so I can replace the seals. My question is, where could I buy the tool? It is shaped like a horseshoe with a pin sticking thru each end to grab the "top" of the cylinder and unscrew it. I'd like to own this tool.
Thanks,
Gary
steve
02-20-2001 20:00:27
 Re: 3 pt hyd cylinder tool in reply to Gary Fry, 02-20-2001 18:04:17
It may not be an "allis Chalmers Tool" Its called a spanner wrench. Snap-On and other used to sell them. You need to know the distance between the two pins and the diameter of the pin. They should have a series of sizes available. May also be able to get from a tractor equipment dealer like J.D. or I.H.
