185 3 point hydrolic cylinder rebuild...
John
03-03-2001 12:58:10
...looking for info on how to disassemble a rear 3 point lift cylinder on an AC 185. The cylinder has the large operating rod/piston.
Have rebuild kit, need to know how the darn thing comes apart.
Thanks, John
ben
03-03-2001 13:21:55
 Re: 185 3 point hydrolic cylinder rebuild... in reply to John, 03-03-2001 12:58:10
john. remove the inlet hoes take small screw driver work off snap ring through inlet hole into the valley pull cly. out replace packing reinstall. i belive the kits come with a new snap ring so you need to use it
John
03-04-2001 10:26:01
 Re: Re: 185 3 point hydrolic cylinder rebuild... in reply to ben , 03-03-2001 13:21:55
...thanks Ben, worked fine. The kit did have the snap ring.
