Head
acd17toy
03-09-2001 21:05:06
have antifreeze seeping from head gasket on 61 d17 gas what is the torque sepections for this tractor
david l wilson
03-12-2001 23:35:42
 Re: head in reply to acd17toy, 03-09-2001 21:05:06
tighten the 1/2" cap screws and 4 studs at 90-95 ft.-lbs and the 7/16 cap screws to 70-75 ft.-lbs
recheck after reaching operating temp.
David Anderson C-Tech
03-13-2001 05:15:38
 Re: Re: head in reply to david l wilson, 03-12-2001 23:35:42
Check the block and head for cracks, you may have to "pin" any freezing cracks in the head and run 3 3/8 x@ 8 bolts across the block between the wet sleeves just below the sleeve lands, I've been running a 226 ci. gas originally from a WD45 in a D17, it's been pinned and bolted for 20 years now.
