Fair price for WD
andy
03-12-2001 20:29:31
I will be going to an auction soon that has a WD with a wide front. tractor runs excellent rubber is good needs a back rim. 12v system. Good sheet metal. Im in ohio. Also is there anything I should look for that might go wrong with these tractors? thanks for the advise
Tom
03-13-2001 14:27:41
 Re: fair price for WD in reply to andy, 03-12-2001 20:29:31
Check the shift lever boot. If it is in poor condition there may be water in the transmission, which may or may not have done any damage---yet.
John (C-IL)
03-13-2001 06:14:46
Check the clutches and brakes. If you can drive it check out the transmission as far as staying in gear. The wide front and good rubber adds to the value. Here in Central Illinois that tractor would bring $1500 to $2000 if everything is good. John
