AC 175 DSL
wood-ranch
03-21-2001 17:04:08
I just looked at a 175 with an allis loader. engine sounds good tires are pretty bad but has rear wheel weights. Problem is it jumps out of 3rd gear. How hard is this to fix?
ben
03-22-2001 12:30:27
 Re: AC 175 DSL in reply to wood-ranch, 03-21-2001 17:04:08
big job. you have to remove both axle housing 3pt hitch split the tractor at transmission housing ,remove spider ring gear then working fron the front of transmission, remove two speed clutch and then the pinion shaft.
