175 head gasket
Steve from Tn
04-21-2001 15:51:14
Had a valve job done on my 175. I need some information on putting the head back on. Which side of the head gasket goes down? What are the torque specs on the head bolts and the rocker arm bolts? I appreciate all the information I get off of this board.
Bruce Nelson
04-22-2001 07:49:03
 Re: 175 head gasket in reply to Steve from Tn , 04-21-2001 15:51:14
Look at your gasket & along one side of it, you will notice three water ports. These control how the coolant flows through the engine. You will notice, one of these holes is very small (restricted), the center one is larger. and the last one has the largest opening of all. Position the gasket (up or down) so the largest water port is rear & the smallest port is forward. Torque the head to 90-95 ft lbs, 40-45 for the manifold & smaller head bolts, 25-30 for the rocker shaft.
