1-1/4 TO 1-1/8 PTO on AC B
Dan Meyers
05-10-2001 09:29:59
I've just purchased a Woods L59 mower for my '38 AC"B". I now have a PTO to pulley problem. My PTO is 1-1/8" tapered and the pulley is 1-1/4" ID. I heard you can shim or weld, or get the replacment shaft. Can anyone who might know the best way to mate these two write back?
Thanks,
Dan
Peter J
05-12-2001 09:32:42
 Re: 1-1/4 TO 1-1/8 PTO on AC B in reply to Dan Meyers, 05-10-2001 09:29:59
Dan,
I have a Woods L59 on my B and the drive sheave goes on the tapered belt pully shaft of the side of the housing. It doesn't go on the pto shaft.
Ted Seifert
05-10-2001 21:26:17
Others have commented on the pto splined shaft. What you are talking about is the tapered PULLY shaft. The early B's had a smaller shaft, I would contact woods to see if they have a different pully. Otherwise I would change to a pully shaft from a later tractor. shimming sounds messy to me as it woumd be diffivult to keep it from wobbling. Good luck.
Phil Auten (TX)
05-10-2001 11:51:03
Dan,
There are adapters available to increase the diameter of your PTO shaft to 1-3/8". What you most likely need is the style that slips over the shaft like a sleeve and doesen't increase the shaft length. They should be available at farm stores like Tractor Supply co. or Farm and Fleet for just a few bucks.
Phil
Rick in NC
05-10-2001 11:48:58
I would suggest a 1 1/8 to 1 1/4 over-running clutch adapter. I have one for my 1950 A-C Model B with 1 1/8 inch PTO. It hooks right up to my Landpride 5 foot finish mower with 1 1/4 inch drive shaft.
Good Luck.
Dave Grubb
05-10-2001 10:40:09
Have you asked the Woods factory people about your problem? They must have seen this before. Also the Force America folks have all kinds of PTO adapters.
