5040 Engine parts
HTR
05-17-2001 19:36:18
Priced engine parts for a 5040 today, pistons, liners and gaskets, from agco dealer. About $2150 I didn't get around to asking about bearings rings or valves. Can this be right? I can buy a rebuild kit for an 855 cummins for half of that.
The problem is the engine has been run with the intake hose off for a couple years, not much left of the top end.
I was told I had to know the inside diameter and outside diameter of the liners and if the pistons were marked A or B. How complicated are these things?
Rick
05-28-2001 08:29:33
 Re: 5040 Engine parts in reply to HTR, 05-17-2001 19:36:18
e-mail me your fax # or phone number so we can talk about this. I just sold an overhaul set for a 5050 for under $1500. Piston, rings, liners, rod, mains, gaskets, I & E valves, cam bushings.
As I've been looking thru my 5040 book, it shouldn't be much different in price (depending on piston type & sleeve dia)
Tom from Ontario
05-21-2001 13:48:56
See if you have a dealer in your area for Universal tractors because that's who built your model. They might be able to do better. If you don't have any luck, send me an email and I'll look up the number for Fawcett Tractor Supply in St. Mary's in Ontario. These folks are masters with Universal tractors and real professionals. Goo Luck.
