AC 190xt high-low shifter
John Revels
05-18-2001 20:18:11
I recently bought this 190xt and when you go to neutral from high or low range the tractor still wants to creep along. How do I correct this as i would like to run a round baler with this tractor. Thank you in advance.
ben
05-19-2001 18:26:56
 Re: AC 190xt high-low shifter in reply to John Revels, 05-18-2001 20:18:11
john. it could be a linkage problem but more than likey one or more of your clutch plates in the hi low have broken and not letting it release completly. i have also seen where the bushing under the deck have worn out than it is hard to keep the right adjustment on the hi low. the bushing are on the four bolts that hold the deck on ben
Duey (IA)
05-19-2001 06:39:32
John, I think it is a linkage adjustment. Duey
