1947 AC-B, should I buy it????
Mike T
06-02-2001 20:42:13
I have a chance to buy the above described tractor for $300. The oil pump has to be primed if it sits a while. This is not a problem. I am seeking a tractor to help clear my 5 acres of light brush. What are my options for mounting a bush hog or mower on this tractor. I understand the pto shaft is an odd size but there are adaptors available with over-running clutches in them. Also, it steers backwards from having been converted from narrow to wide front end. There is a parts tractor (and implements???) available for free. I am told the steering box off of this tractor will correct the steering issue. Sorry this is so long but I dont' want to get into a tractor that will need a lot of conversion to clear some brush. Are there front blades available for this type???
Mike T
MikeT
06-03-2001 20:54:54
 Re: 1947 AC-B, should I buy it???? in reply to Mike T, 06-02-2001 20:42:13
Thank to everyone for all the great info. I'll give it some thought and let you all know how it turns out. I plan to locate a 3 or 4 foot bushog somewhere and try to get it mounted. For 3 bills I probably won't pass it up...
Nolan said to prime the oil system by breaking the line loose at the filter and pump it full with a pump can. I found some excellent info on correcting this probem and some diagrams. I also have to see if the parts steering box will correct the backwards steering. The tractor has a bench seat but I suspect it is a c with the front end converted over. I'll try to take some pics and post them if anyone is interested.
John C
06-04-2001 09:27:35
 Re: Re: 1947 AC-B, should I buy it???? in reply to MikeT, 06-03-2001 20:54:54
Thanks for the priming info. I was going to try that, but I figured it'd be harder than that...
Maybe a dumb question, but you found some good information where?
Here's a couple of pics of mine:
John
John C
06-03-2001 20:11:05
I recently "Inherited" a Model B. I got it running but it had no oil pressure. How does one prime the pump?
TIA
John
jeff - jea lawn land
06-03-2001 14:24:29
mike - for that money i would buy it but as has been said - it's not all that strong of a tractor . i just traded mine in ( also bought to clear brush ) on a skidsteer cause it just wouldn't do it . mine had a loader & a blade!
KURT
06-03-2001 13:43:44
I saw a guy on the yesterday tractor website with a front mounted blade. It is possible but it was probably a custom job. $300 sounds good.
steve
06-02-2001 21:09:51
Buy It. The B was a wide front end, not narrow. Either its a C with a B wide front, or its been switched around a couple times. Look at the steering box. If the lever points up it is off a C. If the lever points down it is off a B. Maybe someone just switched the steering boxes?? You can put a rear mower and run off the PTO, their oare conversions, or you can buy a belly mower and run off the rear pully. Can buy rear blades or addapt a front blade. Does it have hydraulics (single hose on the back) You can use this a a simple lift for a belly mower, and conversions for a rear lift.
Chuck Hilton
06-03-2001 06:22:10
 Re: Re: 1947 AC-B, should I buy it???? in reply to steve, 06-02-2001 21:09:51
It sounds like a great deal but be sure about the job you plan to use it for. Don't get me wrong the B is a great tractor I own 2 myself. But it is very light and under powered to run a bush hog type mower. I run a Woods 6ft. belly mower to maintain a couple acres of permanent plantings and it works extremely well for that. For rough mowing I have a Ford 850 (about 45hp)and a 5ft bush hog type mower.This mower/hp combination seems to work well together untill you need to use reverse while running at PTO speed and that is just way too fast. I hope this will help with your decision. Remember it's a good tractor when used within it's limits. Chuck
