200 allis inj. pump.
john
06-19-2001 06:39:22
we have a 1974 allis chalmers 200 with a little over 2000 hours we bought it 10 years ago with a new inj. pump and a bout a week ago it started smokeing real bad worse then it usualy does and sounds like it misses. we have talked to a diesel mechanic up the road and he said to try this cummins diesel cleaner. but 2 other people have said it sounds like the pump???? what is your suggestions? please tell me what you thiunk we are in the hayfield and are in need of a tractor. also do you know what it would cost to have the pump rebuilt?
Sandy Lake Implement
06-22-2001 17:50:57
 Re: 200 allis inj. pump. in reply to john, 06-19-2001 06:39:22
Definately check out the injectors 1st. Bill
Matt Sheaffer
06-22-2001 09:25:03
I had about the same problem with the injector on my 200. I had mine rebuilt for $750.
chip
06-21-2001 19:39:55
Could be a number of things. I assume that you have replaced the air filter. That would cause much smoke. Have you replaced the fuel filter?
You wouldn't be out much trying the Cummins fuel system cleaner. I would try injectors first, and pump second. Pumps usually cost 4 to 600 dollars to rebuild.
