39 B wont start
ANDY
07-06-2001 19:15:50
Got the B back together from being a bought as abasket case. Set the mag in just like the book says. Ive got good spark and plugs are wet. It will fire once in awhile but not concistantly. THe man I got it from said he replaced the rings. Tried to pull start it got smoke but no fire and plugs were wet. I dont know what else to check. Any ideas? thanks in advance
steve
07-06-2001 19:33:09
 Re: 39 B wont start in reply to ANDY, 07-06-2001 19:15:50
Are you sure you are firing on the compression stroke, or the exhaust stroke. Crank the engine slowly untill the front cylinder comes up on compression, you can feel air coming out the spark plug hole. When the timing mark on the flywheel lines up, check the mag is pointing at no 1 plug wire. You could just be 180 degrees off.
